Ignition coil wire connector question
skippy
Does anyone know where I can buy the male end of the waterproof wire connectors coming off the coils? One plug is white the other is blue. I was adjusting my TPS/idle and accidentally tugged to hard on the air plenum to make room and pulled the black wires out of the blue and white male ends. The little interior plastic piece that locks the wire spade into place broke off and the wire will not stay put. Hopefully this makes since! Thanks
I have a bunch of those from the pairs that I ordered to use for my TSS Bypass Jumpers and other electrical upgrades I make for my own sleds. I can send you whatever you need. Did you pull the pins off the wires and need the complete set? Connector housing seals and pins? Note they require a special crimper, also. If you'd prefer I can just trade you coils as I have a few spares, and when I get yours I'll fix it. PM me if interested in either option.
Sumitomo 6187-2171 is the Mag side coil connector on the main harness
6180-2181 is the mate.
Sumitomo 6187-2175 is the PTO side coil connector on the main harness
Not sure if they are the same except for the color... Try it out on the other connector for fit.
Mating connectors... I dont have the number for... but some searching should come up with it.
Edit:.... easier to go with LH's option... He's sent me parts in the past... arrived fast at reasonable price.
http://www.corsa-technic.com/category.php?category_id=107
If you want to source it yourself; the mating connector is in MH's link, click link, click mating connector and select color and seal / pins size. Easy as well. My offer stands though.
Thanks for all the information everyone, much appreciated!
Loudhandle incoming PM. Thanks
Another question
Can someone do me a favor and check their sleds coil wiring for me please? I went to install the new white and blue male plugs and I can't remember the color match up on the blue plug connection. Here's what I think is right... LOL
Blue connection: White wire to red wire and black wire to white wire? Thanks
That is correct. The blue connector is cross connected as you describe, the white is straight connected (like color to like color).
