2015 MH Drive Bearing Update Kit
This update kit will fit any 2011 – 2014 Mountain Horse kit and will update your drive system to 2015 specs. The update kit will make your drive system 100% stronger and will make your axle bearings least for years. The kit includes all parts needed to properly rebuild your drive axle bearing system.
• Available 10/1/14, call to pre-order (208-255-5644)
• Limited time offer $150.00 if ordered before 12/31/14
• Kit includes: 3 Double row bearing housings with 4 bolt mounting flanges with bearings assembled in them, 1 4 bolt hole drill template for bearing installation, 1 Replacement bearing for brake disc side, 3 Locking axle bolts and washers, 4 Key ways for sprockets and brake disc, 1 Upper axle spacer to accommodate the new wider bearing, 1 Lower drive axle that is machined to accommodate the new wider bearings
• Note: Axle does not come with new drive wheels. Installer will need to Remove and Replace them from the old axle.
$150.00 Your never going to get a better price, Just price out these parts before they are updated the lower drive axel alone lists for $170.00 This is the deal of the century. Even If you have not had bearing problems you need to do this update
