Can you buy idler wheel bearings separately from the actual wheel? Would NAPA or somewhere like that stock the correct size bearing? My wheels are fine, the bearings are getting loose though and causing the wheels to angle out slightly, which I think it causing my track the wear out the hyfax at the front of the rails a little more than usual.
I recently had to get a replacement rear 8" Idler/Bogie wheel from my dealer and he said I couldnt just get the wheel I had to get the whole wheel/bearing set as it comes in one piece. So Im assuming they are gonna tell me I need to replace the whole wheel if I go to the dealer.
