Ok, I this sled never used to do this, but what happened is I was riding last week in some really deep powder, I hit 1350 on my EGTS during tractoring through it, and somehow the sled died, which I had thought was perhaps due to lack of air.
Come to find out, the 1/8" poly line that supplies boost pressure to my EBC and fuel pump as part of the BD kit had apparently gotten too close to my pipe and had a hole melted in it.
I replaced the poly line this evening, routed it and tied it down so its moore away from the pipe and added more rubber tubing insulator, etc...
I have not yet actually ridden the sled again under boost.
But what the sled is doing, even after warming up for 10 minutes, is varying the idle by like 500 rpm. When I first start it up from cold, it will go from 2100-2200 rpm like it always did back down to around 1800, but then after about 10 seconds it comes right back up to 21/2200 rpm ... stays there for 20 seconds or so, then goes back down to lik 1600 or so .... then right back up to 2200 ... if I blurb the throttle, it settles down to 15-1600, but then after about 5 seconds its back up to 2200 rpm ...
Any ideas on what could possibly be causing this? It never used to do this even after the first couple rides on the turbo, so I'm really kinda confused as to what changed.....
Any help appreciated, thanks.
