Hello, i have a question about high idle for a 2011 800. After a cold start up my sled will idle at 2200/2300 for awhile. Id say for about 1 to 2 minutes, this just seems like to long especially when its extremely cold out and idling at 2300 for so long, it then drops down to 1800/1950. Is it just timed in the ecu or is it when the engine temp hits a certain temp? Even if i have it in a heated garage it will do this the same. My tps is set to the factory spec exactly as per PCV readings, ive confirmed the readings with a voltmeter as well.
