almost ran with that and modified my stockers but I found a set of TKI's so Ill just pull a couple extra hours at work insteadI bet if you measure the change in geometry, the upper bolt will be moved exactly 3/8" forward....
I'm thinking of doing the same thing. Which Riot spindles are those? Year? Are those the normal top spindle bearings as well?Took some pictures of the TKI/Riot setup on a 2022 Alpha sitting next to a stock 2014 with the ski bolts lined up.
I'm not sure which year for sure to get that color as these are on a buddies sled, but if you look at Riot (not the X) models for the past couple years or the snowcross sleds they have the lift required. The top ball joint, jamb nut, bolt, and triangle nut is the stock part for the mountain sleds.I'm thinking of doing the same thing. Which Riot spindles are those? Year? Are those the normal top spindle bearings as well?
B
Gracias, I'll have to go through the fiche to see those green ones.I'm not sure which year for sure to get that color as these are on a buddies sled, but if you look at Riot (not the X) models for the past couple years or the snowcross sleds they have the lift required. The top ball joint, jamb nut, bolt, and triangle nut is the stock part for the mountain sleds.
Edit... 6* less caster then factory 2016-23Found that with the 6* positive caster on the new aarms it did increase the front height 3/8-1/2”
