C
colorado logger
On the EBC but I need some HELP and some #. Here is my current #
BASE DUTY CYCLE 0 + ALT =10
ALTITUDE COMPENSATION ALT CMP 100
PUSH TO PASS SET +HP 5
I'M not sure but I think, the only change I have made is push to pass
I have zero to -00.7 on the psi in control box.
I took a short ride at 8000' actuator rod was about 3/16 to the tight side and the push pass was 90 (not sure). I had to let up because seeing over 10 lbs of boost in very short distance.
Came back and backed off actuator rod just to no rattle and set push to pass at 5.
Got dark so did not get a chance to ride after adjustments.
Any help would be appreciated.
