I need a front cooler 02 800rmk
C
cranktwister
I found a water leak between the tunnel and front cooler tonight(currently bummed)I pressurised the coolant system and it started leaking at the front of the tuunel,Anybody have to change one before?Anybody just delete the front cooler or install a larger rear cooler in place of the front?Anybody have a cooler they want to sell? Thanks Crank
You could run without that front cooler if you install a bigger tunnel cooler. There are 2 rows of rivets that hold it in i would pull it and get it welded and put it back in if it were me.
Ive still got one in a bulkhead would have to remove it 50.00+ shipping
Thanks you guys,I got pissed off and pulled it,welded it at work(spot weld had cracked)and installed it the next night.I appreciate the offer on the cooler,Hopefully I can get back to tuning tommorrow,(New slp pipe)yeeeeh haaaah! Later Crank
