I have a 850 fuel question.. Mixing leaded and unleaded?
801_FuNk_801
Just installed a Silber turbo on my G4 850. Was told to mix 110 with my 91 so,
This is a two part question
1. Can you run leaded fuel in a skidoo 850? Which I believe is fine, being 2 stroke? If so..
2. Opinions on mixing 110 leaded with 91 unleaded?
I use non-ethanol in my 850
I running a silber turbo on my 850. I am running 50/50 av gas and 91 unleaded. Av gas is leaded and works fine. It can build up on plugs and o2 sensors but I think that more when you running strait av gas. I have also ran 110 and 91 when I couldn't get av gas. If I are wondering if they mix. The answer is yes and no worries.
Sent from my Pixel 3a XL using Tapatalk
Thank you
Why the AV gas over the 110, if you don't mind me asking?
I just run it because the airport is 2 miles from me and it's normally cheaper.
Oh, ok.
I have the opposite going on. I can get 110 2 blocks from my house and the airport is about 10 miles away.
You will not have any problems, I run either 110 leaded race gas or AV 100 and no-lead 91 octane in my Boondocker 850 turbo without any issues. Generally mix about 30% race/AV fuel to a tank of 91 no-lead.
