Hyfax change
Exchanged the hyfaxs already 2012 kit ,due to the old ski handleing had to lean to one side frequently ,my balance is more to the right ,so that hyfax wore more ,I dont have a fancy skid lift so just put I lag bolts up through my shop ceiling into the truss than just used tie down straps hook to the grab bar to raise track up ,rolled track till hyfax can be seen through window ,take out the small #2 screw countersunk at tip of hyfax (driver end ),also remove anti stab tips off rails ,can use a block of wood or hard plastic to hit hyfax backward ,might have to loosen track alittle ,only takes twenty minutes round trip to take off and install ,next season Ill in stall new .
Were you able to remove the hyfax through the track windows? My hyfax are more than 1/4" wider than the track windows.
Today I ultimately moved the rear idler wheel forward and removed the upper rear shock bolts to create enough track slack to pull the track to the side and slide the hyfax straight back. This method worked, but if anyone has successfully removed hyfax through the track windows, I'd love to hear about your method so I can speed up the process next time.
Must be a difference between the 2012 -2013 track ,2012 track was cut to fit ,2013 was custome from Camoplast for Timbersled .My hyfax slipped right through the window plenty of clearance .
