D
I have 2017 FE501. I want to keep my airbox and not replace it with a pod filter (they are pricey $300+) .
So I grabbed a pre-filter that fits my cage. and some pre-filter material and some round frog skinz hole covers.
I was thinking put pre-filter over my existing cage, should I still put my foam air filter in? If so should it be oiled or not? the oil attracts snow but also helps to resist water/moisture
Then I have to figure out a way to keep snow from getting into the air box and I can't find an easy way to cover off the openings into the air box with the pre-filter so I was thinking, plug the slotted air passages with foam weather stripping to block them completely. Then for actual air flow I was thinking drill two 2.5" holes in the plastic side panel and cover those holes with Frog Skinz prefilter. I figure this would be a good way of letting air in and keeping snow out. Does that make sense or am I in for a big surprise am I setting myself up for failure?
What have you other Husky owners done with the existing air box?
