Got a friend with a 08 700 RMK. He was wondering how to test his voltage regulator to see if its OK! His sled does't idle at times ,and wont go into reverse and dies. He tested his stator and that was fine so he's thinking VR? Thanks for the Help!!
Kipperdavis is referring to my sled. I will run great for a while once it is warmed up and hit the trail about 10-15 mins on the trail will start cutting in and out. But it will not completely die though, but it will run wide open with no problems. If you shut it off for a 5-10 minutes and start it will idle so low that u can get it in to reverse when u try to start it back up again the dash will blink and clicks and if u hit the throttle it will die. Try and start it up again and baby the throttle to get it to run and it will go. Not sure what it my be it had a new stator put in around 200 miles on it and it has 800 on it now. Any ideas let me know? Thanks
