How to remove sway bar from Rev
tip it on it's side...it literally just falls out. Know this the easy way b/c when i was removing mine was trying to jingle it out and tipped it to see what it was hooked on and presto!
never going back tho so cutting is always the fastest.
I had mine up on the lift and unbolted the connecting links. After you take the brackets it just slides out. The belly pan was off so that made it easy. The to clean up the look I fabbed up a black plastic cover on the clutch side. Looks good and drives great. You will likely want to tighten your front springs a little.
