I have a 02 700 edge and I need too mesure my crank run out. How do I do this/ what tools do I need? Thanks guys!
Set up the dial indicator approx 1/2" in from the end of the crank.
Remove the spark plugs and rotate the engine over by hand.
.002" to .0025" is the ABSOLUTE MOST I would want to see for crank run-out!
The 700 has a couple of threaded holes in the front of the case that you can use a scrap piece of metal to bolt to and mount the dial indicator on.
IF your crank checks out to be within spec, do yourself a favor and send the primary clutch out to be balanced. It will extend crank life and be noticeably smoother
Would something like this be precise enough or is there another supplier someone could recommend?
Thanks
http://www.harborfreight.com/clamping-dial-indicator-93051.html
I use a piece of steel flat stock, clamp it onto the aluminum guard between the clutches that covers your speedo drive with a pair of visegrips and set the magnetic base on that. I just bought a BB800 on saturday for cheap, checked the runout, it is 0.0085DOH
It sounds like you are attaching to the chassis. This usually won't work because of rubber motor mounts throwing off the reading.
I have heard that crank runout can be off after doing major jumps or drops...
It will be off initially and then later be alright.
Anyone know the truth to that?
