buy an xp and clutch it you can get 60 mph...
I was going to say clutching will get you real close but didn't feel like fetting ripped on.
I will probably get ripped for saying this but I built a do everything sled, starting point was a 08 XP TNT at 400lbs.
Ending point is a 450 lb full wet mtn sled, trail sled, crossover sled etc. with a 41 lb 16 X 137 X 1.75 track. For comparison a stock 154X should be around 523 lbs full wet.
First run in the mtns without much tuning, just guessing at Grand Mesa, CO, 10,000 ft about 30 degrees in 20 inch of fresh from night before on 8 to 10 ft base, flat open meadows about 1/2 mile runs possible would hit 40 to 43 mph immediately and climb in overdrive and then a little overwind to 55 mph when I had to stop for the trees.
I think made possible by very light track, short paddles and very light sled that treds very lightly in the powder and a 8 lb primary clutch. It has the same flotation on the track as a 154X but a bunch better flotation on the front end as the front end is 40 to 50 lbs lighter than the 154X
Good Luck
I would think a 800R with a 146 track set up well for clutching would exceed 60 mph under those same conditions, at least it better or if it was mine it would be gone.
hardpack!!! no installation, no tuning, no clutching for elevation. just wait for spring and hit your favorite climb just hope you keep going up, today king kat ron found out what its like to go backwards, without reverse...
i thought they weighed the 146 and 154 in the snowest mag and there was a 2 pound difference...
