I am unsure on which way to move the cams in order to decrease compression on a nytro? I know it may be hard to explain through message but any info may help.
You will have to slot the cam gears.
The proper way to do it is get a degree wheel, tdc gauge and dial travel indicator.
I just did this on my vector motor. You want to get the lobe centers to 112-114 on both the intake and exhaust. You can do some reading on ty4stroke.com and there is some good tuturials on doing it. It is pretty in depth though.
Once the cams are moved the dots will be towards the middle on both the exhaust and intake.
1. Could you show pics of these tools?
2. Do all the turbos and engines reduce the overlap the same amount? i think impulse is 3.2mm
3. If so does anyone want to sell the used jig from hurricane?
It is very easy just take out one of the spark plugs, it runs more efficient, That is what i did on my supercharged Venture and it runs like a champ..Good LUck my friend..
Learn how an engine works before you humiliate yourself on this forum!!
Love Marv!!!!:bath baby:
:fly pig:
