How to decode "service light"
here is an '06 trouble code chart. The flashes will be fast 1-10 times, then a short pause. If more then one code is going on they will do one code, then pause, then the other for example, 3 flashes-pause-5 flashes-pause then start over again. Quoted from sno_mo_racer in fouling plugs thread.
I know its for an 06 but I think, not 100%, that all of the codes are the same.
He said service light not check engine light. To shut the service light off, start the machine, scroll through the screens untill you see the service screen, hold down on the mode button until the service is flashing, release the button, push down untill it says off, then push up once to set it.
My bad, I read decode and automatically thought he was talking about the check engine light. As stated above, if it is just your display reading service, that can be just turned off. It just reminds you at a pre set interval when the next service is due on your sled. Sorry about the confusion.
