How to clean exhaust valves
goforbroke
So getting to the 1000 mile mark and want to clean the power/exhaust valves. Anyone have any advice. I searched on hear and understand I need to pull steering post. Then careful as things might fly?
thanks for any help. hoping to avoid digital wrench after i'm done.
No guarantee that you will not need a relearn afterwards. I have not yet but that is me.
Nothing really to fly, there is 2 springs on each valve holding the second guillotine. The spring really stay put but the guillotine may fall.
I only removed the lower block so that I could pull the post over enough to slide the valve assembly out. I myself disconnected the cable from the motor so you could manually pull the valves up giving you room to remove it out.
