how to check resistance in a stator?
how could i check res. in my stator to see if its working right or not? what wires do i need to use and any special way of checking ( by pass the computer or do i go through it?) what #'s would i be looking for on a "good" stator?
Thanks!
Dave
i have not tested a stator myslef, but if you understand the pics, then they might help you..
personally, i would rather the dealer tested it to make certain its done correctly...but if you end up getting it rebuilt..the person who does the work will need the info from this charts..
good luck...
ok thanks, when my recoil broke i was in a bowl and i had no other way of getting it out but to drive it out (huge shavings afterwards). started it off the clutch and drove it up the hill and got out then on the other side it died. i looked at the guages and when the engine died the guages were still lit up for a second after the motor stoped. if the stator died would this happen? what voltage does the injectors run on as well as the computer? what should die first the motor or the guages if the stator were to fail. or does this sound more like a crank sensor?
ok turns out the stator and flywheel shreded some metal between each other. not much damage on the stator... the top 2 posts have some chafing on the sides ( thin wires) and everthing else seems good.the flywheel has looked better. the inside alum/tin shield around the magnets is fairly chewed up and the cps tabs are bashed up in the front, all 7. and the 5 tab sensor is chiped on the side, other one seems good. we cleaned it up and lightly put the flywheel back on, pulled the plugs and gave it a few pulls. still has a hard bright spark. so did i take out my light coils or somthing else? if i still have spark does this mean its still salvageable? havent checked for res. yet tho. fighting with gas tank lines.
PS: if any one has say a good recoil and flywheel/stator and are around the vernon bc canada area, i might be able to take em off your hands:beer;:beer;:D
