How much pressure in Fox Zero Pros
set the fronts to 200 and the rear to 250. this is for a somewhat stiffer setup....what i run on my race sled. always put a few psi more than what you want, because you will lose some when you pull out the needle.
yaup Zero Pro X's. Maybe the X makes a difference, but the numbers I posted are in the range specified in my race/shop manual. Im sure mtn sleds run significantly less pressure.
