E
EEEK FACTOR
I was doing a little tinkering, and decided to check the oil pump on my turbo (2010' BD KIT, garret turbo)so I disconnected the top oil line and fired up the machine. The oil was dripping out very slowly which concerned me, so my buddy hooked up a 12 volt power supply to the pump and the oil started to come out on a steady, perfect stream. My ASSumption is that the machine doesnt quite make 12 volts at idle and should start to pump harder once you get in the throttle. Are my assumptions correct or am I simply an A$$?
