How Much Chain Case Oil
How much chain case oil do you put in a nytro with reverse?
Oil drain bolt:
16 Nm (1.6 m · kg, 11 ft · lb)
Recommended oil:
Gear oil “GL-3” 75W or 80W
Oil capacity:
0.20 L (0.18 Imp qt, 0.21 US qt)
Chain slack adjustment
1. Adjust:
• Drive chain slack
Adjustment steps:
• Loosen the locknut 1.
• Turn the adjusting bolt 2 clockwise until it is finger
tight, and then loosen it 1/4 turn.
• Hold the adjusting bolt 2 in place while tightening
the chain adjusting locknut 1.
Drive chain adjusting locknut:
25 Nm (2.5 m · kg, 18 ft · lb)
