How is the DD vented on a 2005 M7
They are pretty sneeky sneeky my man... but through the secondary hold down bolt out the splined shaft. Which is why you have that odd groove/hollow on your clutch bolt.
Cheers
Coxy is right. Look closely at your stock DD bolt and you'll see it has a hole pin drilled through it.
If you're using an aftermarket deflection adjuster, the allen bolt will have shaved down threads on one side.
