when the primary is at full shift and the belt is riding at the top of the sheaves how close should the belt come to the top???? thanks
Mine runs up at the top on a climb. I think my backup clutch is off a bearcat, which looks very similar to the m-clutch. Either the throw is shorter, or it's getting stuck and not allowing full shift.
if you want to know for sure, take a sharpie up w/ you next time.
before you do a good sized pull, make a nice fat mark on the inner sheave from the center to the top.after your back down, check and see how much has rubbed off.
The M7 clutch is suppose to hav the ballance ring but I am pretty sure the weight of the clutch won't affect shift out, only the ballance of your crank. I have been running my clutch for 3 years without the ballance ring becuase the person I bought the sled from put a replacement clutch on and never swapped the ring over. Hoping I don't wreck my crank over time.
What sled are you running? Care to share your clutch setup, elevation, engine mods and track speed? Trying to figure out what my M7 is capbable of.
