I have a skidoo that i bought with a high performance clutch and it dose not engage to about 5000 rpm's and it feels like it is sticking. What can I do to make it engage at a lower rpm and smother. Thankyou
That will bring the engagement down slightly, but mostly lower your peak operating RPM.
If it doesn't have the ramps with the "bump" in them, going to a lower start rate spring is the logical first step.
If it doesn't have the ramps with the "bump" in them, .
and if it does have those ramps, then what would achieve the same thing?
nate
I need more info, but if you have access to a clutch balancer/tester you can see if your vertical axis alignment is causing a higher than normal engagment. You could also try and paint your springs different colors to change their pressure rates along with a carbon test on you exhaust pipe which can affect clutching adversley.
I am staying at the Holiday Inn all week if anyone else needs any help.
