HOW DO I KEEP THE TURBO IN THE OIL TANK
otist
I HAVE A TM8 09....BOONDOCKER TURBO....THE TURBO KEEPS WANTING TO WORK IT'S WAY OUT OF THE TANK ...ANY GOOD IDEAS FOR A SIMPLE FIX?
fix
I took a small piece off flat iron and drilled a hole for the turbo and a small hole for a spring and mounted it to the bottom hole on the turbo then drill a hole in the oil tank and install a bolt with a fender washer on the out side and a lock nut on the inside and then put a exhaust spring in between them and it holds them together.I will try to post a picture tommorrow.
[/IMG]
