How do I check mileage on a non-running 2007 dragon 700?
I acquired a 2007 dragon 700 recently for a good deal (if I can get it running cheap enough). It’s clean, good track, all around nice shape. Any way, I got the sled non-running and figured it out to being a bad stator. I was wondering if there was a way to check the mileage on the sled without it being able to run?
there is a few plugs in the harness on the left side close to the hood hinge and electronics cover. they won't be marked but you can power up the ecu, or the dc side of the system with a battery. brown is always ground on a polaris. the little odd shaped two pin is the fuel pump. when you power up the correct connector the display will come on.
  • Like
Reactions: TRS
