how did you setup you suspension on 08 xp 163
put the rear spring adjuster in the middle , on the hardest if your 200 plus .
make sure the track hangs 2 inches off the rail or it will be to tight when it compresses .
front sock in the skid is pretty close stock , if your an aggressive rider turn the adjuster two full turn more tension .
front shocks usually run around the two and three mark .
Im bigger so i cranked up my rear springs to max. Front shock was left stock setting but i had to suck the limiter strap up one setting. I was getting really bad ski lift on steep climbs and loosing speed.
Chaz
the rear shock on the 163 is junk, mine was blown in the first few rides....got a new one that was better, but this sled really needs a drop down bracket and better shock in the rear skid
