1
144ProX2
New member
Just purchased a 600 x2 with a stock pipe and a Hot Seat pipe. I am going to sell the hot seat pipe. There is a small nick out of the Y, other than that everything looks great! Everything is included as if buying new!
This is from the Hot seat web site
Chubby Single Pipes
Single Exhaust Systems
All of our single exhaust systems, the Fat Daddy and the Chubby series undergo countless hours of testing and development combined with hours of design and fitting. We have taken the time necessary to produce the best single pipes for your machines. Here are some of the key benefits to using our single exhaust systems;
Straight-Up USA Horspower - Every pipe is designed, DYNO tested and field tested to produce real, reliable horsepower gains. Our pipes are not built for one run across the lake or on the trail, our pipes are built to last, our pipes work!
Ceramic Coating - All of our single exhaust systems come with a long lasting finish that offers a great look while also acting as a thermal barrier to keep heat inside the pipe for optimum performance.
High Flow Manifold - Most of our single exhaust systems come with a new high flow minifold for peak performance.
Lightweight - All of our single exhaust systems are lighter than the stock system. You can expect an average weight savings of about 5 lbs.
Great Fit - All single exhaust systems are designed to run into the stock muffler for simple installation.
Quiet - You can expect stock sound levels while using the stock muffler.
Instructions - Each single exhaust system comes complete with a full instruction/ set-up sheet which included jetting specifications if needed, clutch set-up suggestions, as well as full installation instructions.
SP600PRO-X - 2002-2004 Pro-X 600 (+ 6-7 HP) $525.00
Asking $325 Shipped
Chubby Single Pipes
Asking $325 Shipped
