Hot dogger
No. He is saying to put a bead on the hose clamp to help stop the vibrations. If you put a bead on your springs (across the loops from top down) it stops them from breaking also.
Another option, doesn't work on all setups...
Put it on the can instead of the pipe.
More consistent heat & my hose clamps never break anymore.
I like the RTV idea though... good call.
I had problems with mine coming loose all the time so i went down to the local marine supply store and got some quality s/s exhaust clamps(the ones with the t-bolt and nut) I have three on mine now , problem solved
I got a clamp that has a spring so that it will take vibration and expand for heat it has lasted 3 rides with no problems. I got it at Napa auto parts
All great thoughts ! Thank You ! Love my muff pot. But it thinks it a hot dogger and always moving around !
