holz spindle install help,,need pics of some installed
im trying to install them right now but not sure via instructions where the lock nut is used,were washers supplied r used, ect and want it done right fist time..anybody have a close-up pic i can see ?
locknuts on all the bolts, but they include a small nut that goes on the tie rod bolt.
the thin washers will go over and under the center of spindle (lower a-arm) joint.
just make sure you insert the spacer correctly, the 05 i think it goes on top of the tie-rod tab, 06-up goes on the bottom.
ok seems i did it right but the nut included i used on the center spindle is that correct ?
sure that will work. the locknut they inlcude is just smaller is all, and it fits in the tie rod hole.
hope you get to enjoy that babies...glad it worked out for you. !
Makes sure you loctite all those bolts, nuts, etc.
I can't tell you how many i've seen come loose.
OH YEH...
this happened to me last year...lost the locknut that held on upper a-arm...was a sketchy 15mile ride back to the truck...beat the h3ll out of the top of the holz spindle...
be sure and post how it steers and handles now I'm waiting on you before I get them.:face-icon-small-coo:cheer2:
Cheaper to buy a set of 09 spindles, unless you can find a used set of Holz. I priced them at $139 each new and there are some on ebay for 95.
