I have the rear Holz skid with the older modified Fox Float and have a question about the remote reservoir. The instructions say to fill the main chamber first to 115psi then pressurize the backside of the reservoir to 150psi. When I check pressures after they both have the same psi. Is that correct or do I have a problem? Also I have Floats (version 1) on the front and run around 75psi with the stabilizer bar still in, but it sits lower than the D8 sitting next to it with the stock Walkers. Is that right too?
