Holtzman Atacc
J
Jamesontf
New member
Does any one know if this works on the xp 800R?
Holtzman
ATACC
(Automatic Temperature and Altitude Carburetor Compensator)
This compensator will automatically keep your carbs tuned through all temperatures and a typical elevation change of up to 8000 feet (2400 meters) (see instructions for other limitations). The standard compensator is set initially for operation with -20F (-29C) carb jetting for use with snowmobiles, but can be set to use with any jetting temperature. It is also easily set for any operating base (minimum) altitude. This compensator is recommended for the mountain rider who wants to play, not jet. The standard ATACC will work on almost any snowmobile except 4-strokes with CV type carbs and it is not recommended for 2001-2002 Ski-Doo's with TM flatslides.
The XP 800R TM 40 carbs already has compensation through the ECM for altitude and temps.
Good Luck
I have them on my modded longtracked TNT XP's which have just plain old TM 40 carbs.
