High milers
hard to see, but thats my 96 PSD w/ 161K on it.. not that much I know.. but it's a plow truck... Original everything.
98 cummins 24v with 215,000 miles. 1 lift pump, an exhaust manifold, and u joints for the front end, and lots of tires. Still runs great
my dad had a 79 ford with a cummins 4bt and a hi/lo splitter, that truck had well over 500,000 miles until i piled it up in the ditch. Bent the frame up bad but the motor was put in a tow truck and still runs to this day.
199,000 on a 2002 Duramax. 1 transmission, 2 sets of injectors, and a transfer case. After I quit running stacked chips it has been trouple free. Stock components on a GM weren't made to handle over 450 horse at the rear wheels.
2006 cummins with just over 200,000 Miles and it has an aftermarket turbo big injectors heavy clutch 37inch tires and pulls with my dads and brothers with way less and they can't keep up but just a little TLC goes a long way on stuff she's just getting broke in but some of you guy hole **** like a 5.4L van with 500,000 and some on it thats pretty good because I thought I didn't set still very well out of my cab that guys butt got to hurt good thread the next one will be how low of miles
1990 dodge cummins tow truck bought brand new from my dad towtruck since day one. this truck has put these miles on always towing something it never gets babied at least when i drive it:eek:
1,300,000-1,500,000 miles completle stock engine pump is not turned up
3 headgaskets
1 turbo
couple valve adjustments
still runs strong always starts no matter how cold, but lets just say it turns over really fast compared to other cummins:D
its had several getrags, rearends front ends, had the door ripped off once by a really smart employee, and its pretty rusty now and the frame is broke needs to be welded but other than that its a good ol truck its now just a backup up truck if one of the others are down
2006 dodge quadcab we got it with 405k it was used as a rodeo truck
it now has 437k and is turned into a rollback/towtruck banks intercooler,intake horn,edge juice w/attitude, weighs 11,900 empty halls two cars regularly
04 dodge quadcab 370k just got turned into a tow truck its almost finished
Just a hair over 300k on my 93' Dodge Cummins. Just as mentioned, everything else has been changed, swapped, fixed, or whatever, besides the Cummins. Still runs exceptionally strong.....Well kindof, I think I lost the high side pump now..:mad:
I have a 96 Ford Powerstroke with just under 210,000 miles. Still runs like a champ. Also still running on the original auto!
3 headgaskets
1 turbo
This guy wins.:):beer;
2000 Cummins 2500 185,000
1 injection pump 150k
2 transmissions(1 was the idiot dealerships fault, grenade'd 3 months after they "fixed" it) 160k
1 rear drive shaft seal
1 transfer case input seal
new brakes all around- few new axle seals
Thats about it, wish there was a manual around when my previous truck exploded.
3 headgaskets
1 turbo
Jack up the motor and put another truck underneath it.
01 dodge 234k miles a couple pumps, a couple trannys, a couple front ends, lots of tires....overall an awesome truck, was gonna upgrade...til the wife put the cabash on that:confused:
edge jamer 5's injectors
htb2 turbo
edge juice since 80k
All you guys posting high mile gassers must be fibbers cause everyone knows that after 2 years they are worn out and disposable.LOL.
:D
04 Cummins: 255,000 kms or 160,000 miles...Tranny Just rebuilt...Tows at least once a week.
99 Long Nose Pete: 2,700,000 kms or 1,687,000 miles :D 2 engine inframes, both diffs and one tranny...Hauls every kernal on the Farm :D
2001 chevy 1500hd 6.0 150,000 miles
1 transfer case at 97k
needs oil cooler lines now and a 4 wheel drive control unit. other then that no problems
gets 13 mpg towing 4 sleds going 75. can't complain about that
04 f150. 203k(miles). runs like a top. basic maint, tires. ready for a trans right now, slipping. Spark plugs are an expense but otherwise this thing is getting a tranny and tires and I'm going to keep her. All hiway miles and much towing.
