Hello I was out at our local powder coaters the other day to get my snow eliminators and rear bumper and other parts powder coated the mating black/silver hammer tone coating the same as the AI 37inch A arms I puchased and asked about what they offered for a possible ceramic coating or high heat exhaust coating, like I have read and heard alot about how guys have removed the heat shielding and insulation from the stock Rev 800 pipes and had them coated and the coating held the heat in the pipe and didn`t have to reinstall the aluminum shielding and isulation.
My powder coaters has a high heat exhaust coating and it black or a dull silver, and I showed the shiny ceramic coating of my HPS Can and he said he has the coating like that, that is just doesn`t come out shiny like than cause they don`t have the machine that polishs it to the shiny luster and that they coat motorcycle pipes alot.
So big question do you all think this is the same type of coating like HPS, dynoport and other are using also and that the shiny finish is actually done by a machine to polish it he says you can polish it with like steel wool or possibly a buffer and it would be shiny too, I am actually only interested in the black finish, so is there different types of exhaust coating for the pipe like I mentioned or are they just a durable high heat coating that wouldn`t hole the heat in and make the pipe perform like intended or is this type coating just for durability and surface rather than what the after market pipe makers doo??
any info or suggestions would be appreciated, is it really a good idea to just have the pipe coated in the first place and remove the shielding and insulation? or does the coating actually perform better??
Is there a certain brand number or name to the coating the aftermarket does that would be different to local coaters and what would those be??
Thanks, Wildcard
Thanks, Wildcard
