Who's running an Adapt Turbo setup at 10k+ Elevation? I've got a 2020 Silber at 5-6psi, CnS tuned with Team clutch. 48S helix (can't remember the secondary spring I have in it, it's the CnS venom spring I believe but don't remember spring rates), stock 120-265 primary spring and CnS weights loaded to 76g. Ideally, I'd like to be able to swap primary for primary and only have to buy weights and potentially primary spring, but understand that may not be possible. Sled runs great in current form, trying not to spend a bunch of money and time testing if there are proven setups on the snow, but I haven't found any really great reviews. Interested to hear what others have on the snow.
HI! So I bought a used sidekick kit for my 19, the clutching they run sucks it ran stock secondary spring, helix (48s) and a heavier primary spring and I think similar weight to you. You can totally just go with a primary setup leaving your secondary alone. if you did I'd buy the primary spring and weights and I can send you what they recommend for magnet position and you should be good to go.
I talked with bdx/ssi and bought a complete clutch kit for my 19 with an adapt clutch From them as their prices were very good too! I'm very happy with it and woke up my lazy sidekick kit. get rid of your 48s helix, seriously... They got me on a 44-48 and it takes off like stock n/a. However my throttle chop could be a tad better, i highly recommend a 44-46 helix, at your elevation I'd even go for a 42-46..I'll eventually go to the 44-46, maybe 42-46, a fella runs a straight 46 and his throttle chop is close to n/a. Mines half a second slower.
I want to say the whole kit from them was like 300 USD... Almost half that of others., they custom make and cut helix's so can make what ever you want.
Here's their setup for adapt primary and secondary.
Total weight 69g, 125-290 primary spring., secondary is a 190-260 spring and as mentioned 44-48 helix.
That said in a week or 2 I'll have these high elevation adjustable weights for sale, base of 60g to 75g, I ride 4500ft+ and fully loaded I'm 8600 rpm and 8400 at 6k ft. (which is OK) and can't turn boost down below 5 so they were kind to send me their heavier weight.
This fella runs the straight 46 helix and similar setup with a sidekick turbo kit and Its been the cleanest running I've seen, you'd sware it was n/a
