HEY CLUTCH GURUS-Need help-- diagnosing violent belt "bounce" (erratic belt movement)
A little history-- exploded a 115 belt in wet heavy snow one week ago-- older 115,not sure how many miles were on it, knew I was going to abuse a belt with the conditions and threw it in. Didn't think a 115 would/ could grenade.... It can.
Went for a ride today with new clutch side vents in wet heavy snow.
Last night cleaned primary, pulled weights, cover, spring and cleaned in soapy water and then put in the dishwasher. Pulled secondary apart, installed Delrin, cleaned re-assembled
Rechecked offset and float with Polaris special tool.
Pro RMK 163, 19-42 gearing, stone stock motor
Running 6-8000 feet
10-62 weights, stock springs (maybe 100 miles on primary spring after original broke at 700 miles)
Beginning of season, brand new 0 mile clutch was sent to Indy Dan for balance
Went for a ride....
Pulled over to check belt/ clutch heat and was unpleasantly surprised... They were HOT.
Also noticed-- may or may not be related, the rpm seemed to "hang" around 3500-4000 before idling back down. At first, thought there was snow in the throttle assembly, but it was clear. If I jammed the brake to lock up the jackshaft I could get it to idle down sooner.
Belt was smoking hot. Secondary seemed a little cooler than primary.
Used a tie down and a tree to elevate the rear of the sled. Pulled off side cover and opened the throttle. Watched belt engage and started to raise rpm-- looking for a misalignment or one of the clutches not opening.
At around 6700-7000 rpm the bottom side of the belt would start bouncing violently when under steady or increasing load/rpm. Where the belt runs between the sheaves on the bottom of the clutches, looked like it was being stretched and compressed( like when someone snaps a leather belt to make noise) The belt would jump up and down on the primary sheaves-- almost looking like it was going to jump out. ( track speed never exceeded 65 mph) this was at 1/2 to 2/3 throttle not wide open. Increased rpm and bouncing got worse, never settled out.
Motor and clutches seemed to be steady, not moving around causing the bounce the primary and secondary were spinning in nice circles, the motor (based on lack of primary movement) seemed to be steady also.
Changed belts, same result.
The observed rpm belt jumping coincides with something I have been feeling while riding. At 7000 rpm, the power delvery seemed to flatten out. It would still pull to 8100 rpm it just would not get there very quickly. The snap was gone. Now seeing the belt jumping up and down the sheaves it makes sense-- power is lost in the sheave scrubbing vertical movement that is producing a ton of heat.
Looking at my primary, when I push on the three towers, with the clutch still installed on motor, two of the towers feel solid, one tower "clicks" and the cover and spider seem to c0ck sideways. I'm thinking at 7000 rpm, the spider cocks slightly sideways and now the belt is running in a non circular orbit around the sheaves making for the violent observed motion.
I am going to swap out the primary and secondary clutches off my 155 and see if it doesn't fix my problem.
Sorry for the long winded post... Just tying to get as much information, observations, and symptoms down.
Anybody ever seen this before? Any suggestions?.....
Running 6-8000 feet
Went for a ride....
