Ok, so what should have been the most phenomenally easy part of this project (replacing spindles and shocks on my 900) has turned into be the only part of it I can't complete.
I took the old spindles off with the skis still attatched, not thinking anything about it because I've removed skis off the 06' IQ sleds numerous times in 2 feet of snow to test adjustments, help out a friend , whatever ....
And I have _NEVER_ seen this happen nor even thought it would happen.
Anyways I go to button everything back up, the skis being the last thing to go on the new spindles before I go to set the camber and toe-in ....
.....remove the nylock nut on the inside of the ski bolt .... and ...
smack. The bolt is stuck beyond belief. Now mind you, it will still spin freely. However, I cannot even BEGIN to get it to budge to pull it out. I've probably sprayed 1/2 a bottle of PB Blaster around all portions of the spacers, threaded end sticking out, everywhere ... I've beat on it with a rubber hammer, steel hammer, I even took the torch to it to mildly heat it up to see if I could get the rubber to expand and let the bolt more easily come out ... and ...
Nothing. Nada. Zilch. The thing will rotate freely but it is completley stuck in there, won't even so much as budge.
So, now, with tomorrow being the day before christmas, I either have to find an autoparts store that is open and buy big *** ball join press or something to press this thing out, or see if the local Polaris shop might be able to juse press them out for me somehow.
So far pressing this out is the only thing I can think of, because I have to have skis to get the sled in the trailer .....
Anybody got any other ideas ?
heh this is so much fun
