help!!!
hey i have an 07 m1000 y pipe and can, stock clutching, except i put rock rollers in but i dont think that matters! and i got 57 63 gearing! yesterday in on the main road with about 2 feet of fresh i was getting 7400 rpm, and when i was climbing it would only get to about 6500, sometimes it would only get 6000, but id let right off the throttle and then grab it and it would go back up to 6500. any ideas ? clutching maybe and what to do, any help would be appriciated
Rollers gone , bushing done , Maybe a broken spring in primary . Sounds like clutching for sure .
You might check your power valve cables, on the 07's the clip that holds the cables on the servo motor will come around and touch the cable when the servo cycles and will eventually just cut the cable in half. They came out with a new skinny clip but if yours has the original it could have cut the cable. Happened to me twice b4 I figured it out.
new rollers, the dealership that i went to said the rest of it was fine, but i dont go to them anymore cause they not to bright there! but its almost like its not backshifting, cause if i let right off and grab it again she revs up a bit more!
