Help!!!!!!! With zbroz rear shocks and suspension on 09 dragon
Ok, i went to put everything together and having problems.
1. how is the best way to set camber for the front? nate said neg 1 or 2 degrees from the top of the spindle. How exactly do you measure this? pictures of it?
2. does anybody have extremely detail pictures of the rear shocks and suspension for the 09? Anybody have a better diagram for the rear sissor than the polaris fiche? have a few things i forgot where they went :rolleyes: and the parts fiche doenst give measurements just says chit like "washer"
Polaris spec for camber adjustment is front off the ground, 3/8" rod thru ski bolt hole on the spindle, across to opposite spindle, should measure 2.5 to 3.0 inches from bottom of opposite spindle.
wonder if that would turn out to be the same as zbroz specs once on the ground?
Also, I have two washers that I'm not sure where they go. I just measured them
.80(inside)x1.130 (outside)x .060(thick) any help?
how does one go about adjusting the camber when using arsfx arms? the actual nut for adjustment is enclosed and can't get a socket in there. but without the shocks it will not be at the right height. or am i missing something here????
No one knows... I would assume if the shocks are the same size then all you'd need to do is install and go.
