Hey corey,
I too have a 700 dragon with a silber turbo and live in MN. I was in your boat 1 year ago, first EFI and first turbo. First off let me say this, I am far from an expert and I have never really set my sled up correctly for MN. However there are a lot of guys on here that are very good resources. Many guys have moved from dragons to a 800 pro but much of the tuning logic and principals still apply. Read old posts.
Here are some things to consider.
Are you trying to the run the sled in MN only or are you just testing riding in MN before heading to higher elevation?
You must consider the level of boost that you are running in MN, Silber's standard wastgate has a spring it to that will only allow the boost to go as low as 7lbs. That is if you turn the rod all the way out. 7lbs at 1000' is a lot of HP, as 14psi atmospheric pressure turns into 21psi manifold pressure. With more air you need more fuel, and with more air and more fuel you will get more power. The guys above referenced 110 octane fuel. It is good that you are starting out there, more octane = less chance of detenation and a engine that retards itself. Silber has a chart that has Octance recommendations for a certain altitude and boost level, you should reference that.
Another thing to keep in mind is that you are now producing way more power than stock and will need to clutch for it. I have had to put 78-82 grams of weight in my primary just to keep my sled from over reving. If the sled over revs (8400+ I think) it will retard the engine.
You mentioned Justin's 'stock' fueling numbers. Someone can correct me if I'm wrong but I think that these numbers were set up for the West Yellowstone area. Your sled will correct some for the elevation drop but you should error on the side of caution (more fuel) when riding it in MN. With cold dense air at 1000' you will likely need to add more to the fuel per lbs of boost. Also, like others have said watch your plugs and piston wash in addition to your AFR.
There are some old posts in this forum for checking AFR sensors I would suggest reading those before buying a new sensor. Something to the effect of pulling the O2 sensor and stuffing into a gas rag to see if it runs rich on the AFR gauge.
Good luck.
