Help with my M6 to M7 project
M
M6johnny
I know that there are probably a hundred threads like this, but the search option leaves alot to be desired. I just bought a 700 topend and have a couple questions.
1. Are the power valves the same between the 6 and 7?
2. Where can you send in your ECU to get reflashed? And, how much did it cost?
3, Is there a difference in gearing between the two?
Thank you in advance for your help.
johnny:D
The power valves are different.
You can send your ecu to arctic cat thru your dealer.
The gearing is the same between the two.
