Help with Klim Adrenaline's Boot Sizing
So I went to my local Klim dealer and checked out the 2010 Adrenalines. Man those are some sweet boots. I'm having a hard time choosing the size and need some help.
I wear a size 10 normally in my shoes. I put on a semi thick non cotton sock at the dealer and put on the 10. The 10 seem to fit perfect, however, there was not much room in the toes left, probably around 1/4 inch left after the sock.
I then went to the 11, with the same sock. There is probably 1/2 to 3/4 inch left in the toe and the fit itsn't quite as good (some movement). I then decided to put two socks on. When I do this the fit is pretty good. Almost as good as the 10, except a little more movement.
Basically I'm stuck here. Do I want a boot that is fit with one sock and is it a good idea to not have alot of room in the toe if it gets cold or is that the way to go. I could also go with the 11 and more likely have to wear two socks. Really I need a 10 1/2 :)...
Any thoughts on this would be appreciated.
Try it with the klim sock, its thin but a good sock that breathes
I wear a 13 in shoes and a 13 in Klim
Hmm that has me thinking. I have never worn a size 11 shoe. So you only wear one sock with your Adrenalines and they have kept you plenty warm? I know the sock I tried on was a bit thicker then the Klim sock, I guess I'm worried about how much room is in the toe in cold weather.
Just one wicking sock needed, I wear smart wool socks. I'd get the 10, also the liner might compress slightly over time.
I just bought a pair of adrenaline gtx's and the klim salesman a the puyallup snowshow told me if you are in between sizes and need a half size there is a thin insole that they come with that you put in. The insole should be in the box, also I only wear 1 pair of klim socks with my boots and have never had cold feet.
I wear a size 10-10.5 and I wore the 2008 GTX's in size 10 and now I have a pair of the 2010's in size 10 too. They fit perfect with a Klim or a Burton snowboard sock. I did find the Klim socks like to slide down the leg a bit and bunch up. Maybe I got chicken legs but its annoying to say the least.:beer;
I wear a size 10 in the Adrenalines, and size 10 in everything else, with the Klim socks you will be in heaven!! Have never had cold or wet feet and I just really don't want to take them off after riding!
I seem to be a bit different here than everyone else. I just bought a pr of last years adrenalines at the SLC snow show. I wear a 10 shoe, but work boots always seem to in the 11's. I tried all 3 sizes the show and thinking i was gonna wear wool socks, the 12 was actually the best fit (with room). Went up on the mtn with them this morning (below freezing w windchill...COLD!) and with just a regular pair of average cotton socks my toes actually got a little cold. So, GLAD i left room for wool (or maybe 2 prs?) Thats my .02
I wear the same size in work boots and Klims. I also wear moto-cross socks and my feet have never been wet/cold. Cotton/wool aren't the best for keeping feet dry/warm.
