Help with 07 summit lights
I have checked the fuses , and made sure that they are pluged in to the back of the lights, they have always worked I had the starter recoil replaced and now there not working . I called the service dept and ask if they would have disconected them for some reason and they said no, but offered very little as to what to ck next,Any help would be awesome!
check your relay. Its located near the fuses behind the left side(if you are sitting on the sled) panel. use a known good relay from another sled.
does all of your other electrical work? Tach, grip warmers, tail light....
Yep....gauges not working also I would bet?
I just ck'ed and I have both a working tail light & brake light, and dash lights work fine, I don't have a relay to try at this time any other Ideas?
Thanks
