HELP with 03 RMK 700 jetting and weights please
F
I purchased a sled set up for the mountains. I live in Iowa (1000ft) so I need to rejet. Where could I find a jetting chart and a clutch weight chart? I need a base line to start somewhere. It has crankshop (twins) pipes and high compression head so this will add to the fun of tuning it. With the aftermarket pipes will I need to richen or lean from the stock position?
03 RMK 700
i have a stock chart that came with my 03 700 if that would help you any. not sure with aftermarket though.
Jetting
Go to the SLP web site, under exhaust, they have clutching and jetting charts that you could use as a guide. It's a dowmloadable adobe file in the instructions section.
Jetting needs to be richer than stock when you work on the air box and piping.
