Just wanting some help from guysthat have installed a vipec on a 13 silber kit (or any other brand as far as some of the questions go). Bryce is out riding so just want to get this on and ready so we can get hooked up after and get this running....but i have some install questions.
1- the fuel regulator where did you mount it and can the boost line be the one teed off of map sensor and intake boot to the reeds?
2-i got the wrong injector connectors - just going to use ones on the silber harness does color matter on the injectors wiring?
3-the 3 red and 2 black wires for power and ground-where did you get power from
4- the IAT sensor can it be put in the silicone tube where the previous map sensor was
5- The wiring to the afr sensor where do you get power from or can i just use the one single sensing wire
6- also the log switch does it need power up at the switch or is it getting power where the 3 red an 2 black wires are getting wired in?
Hopefully someone out there can understand what i am asking and give me a hand. Thanks
