help van amberg cooler on nytro
T
tmac
New member
put a van amberg tunnle on my nytro and want to hook up the cooler that came with the tunnle in with the stock cooler now i assume i cant just t in that i will have to run it in series with the stock cooler to keep it circulating through both coolers has anyone done this and if so how did u run your coolent lines
I installed MPI tunnel cooler on mine. Deleted radiator and fan works great. Yes, you run it through the motor.
Do you have a weight comparison between the two? What was taken off versus what was put on?
I don't know the weight saving's but i do know it keeps the sled cooler and keeps snow from building under the tunnel. It also gives you lots of room if you have a S/C.
