Hi everyone,
Just got done with my 700 rotax motor. I ported and polished, RKT head with 13.2 domes, Crankshop pipes, one piece Cabontech reeds on modified cages, yadayada...
Anyhow I go to fire it up and it takes off, pegged, 9 Grand. Hit the kill switch and it keeps running, pull the tether, pull off the plug wires, still 9 grand! Good thing I didn't put the belt on! Finally choke it off when i grab the throttle.
So I look at it for a bit.
Start it up again, 9 grand. But now it shuts off with the kill switch.
Scratch Head...
The final verdict is it runs almost wide open, If I grab the throttle it will spin up a little bit more. Will shut off on the kill switch. No obvious air leaks that I can see. Tore it down again and the base gasket and head gaskets look ok but I am replacing them anyhow. Crank seals were good when I put them in, or so they appeared to be. Throttles are not sticking. I can find anything that would leak enough air to let it run almost unthrottled.
Just wondering If anyone has had this before or anyone has some suggestions at to what it may be.
On another note This is a DPM motor and the main jets in the roundslide carbs are 280. On my 01 700 I built the same last year It had DPM flatslide rack carbs. I was running 540 main jets in that. Though those are big It just seems that 280 Is too small. I'm riding in Two Harbors MN, at about 1000 feet. Any comments?
Thanks all!
Scratch Head...
Thanks all!
