J
j_gunderman
New member
OK fellow 900 folks I need some help. I was out riding this weekend and my sled started bogging around 3/4 throttle. If you nailed it, it seemed to pull just fine but if you feathered into it when you got about 3/4 throttle it would bog and not go above 6000 rpm. worked fine 2 weeks ago. below are some of the things I have checked and it is still doing it
slp pipe and can
timbersled intake
engine compression 125# both cylinders cold
oil pump and cable checked and good
tps tested sits at .93 throttle closed 4.05 throttle full open (did not check with throttle plates completely closed
exhaust valves cleaned found one bellows had a hole in it. both bellows replaced
New fuel filter put in. (fuel pressure before new filter was 60# after new filter was 62#)
Plugs looked fouled put new ones in NGK
Any help/suggestions would be greatly appreciated
slp pipe and can
timbersled intake
