The easiest access will be to remove the seat, tank, cowling, air box (2piece, there is a plastic push dart that you will need to shear off on the front left side, then 2 tabs that release the top half from the bottom for easy removal), throttle bodies, then reed cage. If you are boosted you will want to add the TB boot reinforcement plate while you are in there. BD, Silber, and many others have it.
It's also a good time to check /calibrate your TPS and check your oil pump linkage alignment. I would also replace the left/PTO front motor mount bolt with the ARP bolt from Summit Racing. You might also consider adding additional grounding wires from ecu plate to chassis and to motor mounts. All the above can pbe found with pics in the "Increasing Your IQ" section at the top of this thread. Good time to make some quality preventative upgrades. Good luck. EW
